foresteronw
- Joined
- Oct 29, 2002
- 76
I have recently posted a topic conserning water in my oil. First let me explain the problem and then I will explain what I have found that could be the problem. There is water in my oil only at under the valve covers. There is nothing on the dip stick at all (i know it would be at the bottom of the oil pan though). The oil level never rises, at least I can't notice it. The engine runs fine, this happened at the end of last season and I didn't have time to fix it. I have just started it for the first time today and again it ran perfect. <br /><br />Now were I think the problem might be is with the way my exhaust is routed. I have seen a picture of my boats engine compartment on a different boat and it was routed completely different than the way mine is. My exhaust goes from the manifolds to the risers (rear mounted) and they point forward. The hose stays level to the front of the engine then travels down and outboard at about a 45 degree angle. Then takes a 90 degree turn to the aft and exits out the hull. On the boat with the original exhaust the risers point aft and go immediataly to a 45 degree angle down and then 90 out thru the hull. Now what I am wondering is since mine is ran this way every time I plane off and accelorate forward wouldn't the water in the exhaust just run right back into the motor. I wish I could explain it better. In case this helps I have a 1989 Sunbird Eurosport with an OMC King Cobra 5.7L. Thanks for you help and if you can come up with any question that might better explain it let me know. I can email a picture to anyone that wants to see the way my exhaust is ran, it would most likely help, I am also going to try and get a picture of the way the stock exhaust is suppose to be ran.
