Water in Oil Reservoir?
fixmyevinrude
I read on this forum occasionally of water in the oil reservoir but I dont know how to check for this. Would like to hear how to check and if there are oil seperators like you can get for your fuel system. Also is there a filter or anything that needs attention on these systems? 1994 200 Evinrude LE200SLERS
Chris1956
Re: Water in Oil Reservoir?
Oil floats on water. Simply suck some oil off the bottom of the oil resevoir, into a cler container and see if it has water. I use a primer bulb and some fuel line to suck up the oil.
Water in the oil resevoir is from condensation.
