Water in oil
deanbobber1
If I have a cracked intake/exhaust manifold on my omc cobra 3.0 could that cause water to get into oil?
Don S
Re: Water in oil
Welcome to iboats Dean, Moving this to the OMC forum, you posted in the Volvo forum.
donzi gt230
Re: Water in oil
My cousin's boat with the same motor had water in the oil and it WAS the exhaust manifold. I replaced it and it's been water-free for 6+ years now. The water had to go past the pistons which isn't good, but surprisingly it still has perfect compression and runs great.
Joshua Nichols
Re: Water in oil
Nope,.. More than likely, it's the Block...
This time a year way more than likely...
You can buy a ton of new parts for a cracked block.. Head gaskets... Manifolds... At the end of the day the block is still shot.. Pressure test the block before you spend a dime..
