Re: water in oil
Then clamp off the cooling hoses and put in 15 or 20 psi. Listen carefully to hear where the leak comes from. Check for air leak sounds at the exhaust, the intake, the oil stick and the valve covers, and around the outside of the motor too. There's got to be one unless you fudged up any of the gaskets you did. Which should be your hope, that's cheaper than a block.
