I bought a Volvo Penta powered boat in the winter, its a 5.0Gi coupled to an SX-M outdrive, year 1999. All systems checked out fine, started boat using ear muffs to warm the engine and change the oil before going out to the lake last weekend. I was surprised that oil was totally "milkshake" like, so I added new oil (did not change filter), ran the boat for another 5 min and again only milkshake came out. Today I removed inlet manifold and heads, lots of milkshake in the "V", but could not find any cracked in the block!! Cylinder head gaskets look fine with no sign of leakage between oil and water passages. Inlet manifold gasket look OK, did not see any obvious problem. I'm at a loss, where is the pr
oblem? Any help or suggestions will be highly appreciated. Thank you.
