jluchuk
- Joined
- May 20, 2008
- 43
I have a problem with my Volvo Penta DP-SM outdrive getting water into the drive fluid. When I drained it this year it was a mustard color. My other outdrive fluid is normal. I have been told that the problem is most likely the prop shaft seals. Is this correct or should I look for other problems? Can these be replaced with the outdrive on the boat without separating the lower gear case from the upper case? Is there any special tools or problems I should know about? I have the manuals on this drive but they do not cover replacing the seals and only show and exploded view of the lower gear case. Thanks in advance. Jerry
