i have new oil drain and fill gaskets, shift shaft bushing assembly, complete waterpump assembly, thick rubber washer that slides down waterpump shaft and sits on top of water pump,and new o ring seal that snanwiches between both halves. took out for one weekend and boat seemed to be fine. while sitting on trailer awhile later i noticed unit oil dripping down backside of lower half. seem to be coming out from oring gasket. i took apart only to find water in unit. is it possible water entered thru that? if so is there any tricks to seal it, like some gasket sealant? thanks ken ps when i took apart i did notice the o ring was off on the waterpump shaft, looked up into upper unit and there it was. could water have gotten in that way?
