Captain-Noob
- Joined
- Jun 24, 2007
- 21
...pulled my outdrive and found water in the u-joint bellows. Gimbal bearing and U-joints, yokes are quite rusty as well. I bought new bellows and when I pulled the old one and inspected it for rips, tears rot etc. I could find absolutely nothing wrong with it. I also checked to make sure it was mounted correctly and it definitely was.
So my question is can water enter the bellows from the engine coupler side through the gimbal seal??. Reason I ask is that this boat has been sitting a couple of years uncovered with the doghouse off.
and after seeing a correctly mounted and un-damaged u-joint bellow with water in it I'd like to know where it's coming from. Boat is a '91 Bayliner capri 3.0GS with SX drive.
P.S. new gimbal bearing and seal will be installed.
Thx. guys.
Mikey.
Thx. guys.
Mikey.
