magicbandit
- Joined
- Nov 18, 2002
- 27
I am still having problems with my 1990 formula with volvo penta 454. I have been through hell and back trying to fix this thing. Here are the things I have done respectfully.<br />1. Pressure tested the manifolds and risers with 30 psi of air. Both sides held at 30 Psi overnight<br />2. Pressure tested the oil cooler(tested fine)<br />3. Replaced intake manifold gasket<br />4. replaced both head gaskets<br />5. inspected block and heads for cracks(none visible)<br />6. inspected cylininder walls for cracks(look perfect)<br />7. checked compression(between 130-136 on all cylinders)<br /><br />All of my testing has been done on the trailer.<br />The engine temp only goes up to 150 degrees f. The oil will not clear up. light brown color very cloudy. kinda like a milkshake. the longer i run it the lighter in color it gets. i have changed the oil several times and i see NO improvement.<br /><br />Can the engine ingest water runnining it on the trailer. I have not tested the static line because everything is frozen around here but should it matter when the boat is out of the water???<br />The boat has thru hull exhaust and from the outlet on the riser to the thru hull fittings there is a real nice downward slope on the exhaust pipe.<br />At this point I am very fustrated. with this engine. any opinions and/or suggestions would be greatly appreciated.<br />MIke
