water intake for 1967 100 hp Johnson
alcan
Re: water intake for 1967 100 hp Johnson
The water inlet is located in front of the exhaust outlet. Above and behind the prop.
doodlebug
Where is the water supposed to come out at? I don't see it coming out anywhere.
alcan
Once the engine has warmed and the t-stats open you should see water exiting the exhaust relief port located half way down the back side of the leg. This motor has no tell-tale (pissser), instead it was fitted with an over heat warning light fitted to the dash panel.
jimmbo
There is a 1 inch idle relief about half way down the leg. Water and steam are discharged here.
