imported_TheMan
- Joined
- Oct 19, 2006
- 224
Mercruiser 3.0 with Alpha One.
I replaced the gaskets, o-ring, and impeller of the sterndrive water pump. I've made sure all the lines are clean. This was all after I identified the impeller as being bad as no water was coming up to the engine. (The old impeller was toasted.)
With water supplied to the sterndrive by muffs, the system still isn't pumping water up to the engine. I have taken it apart again and double checked to make sure it is installed correctly. I couldn't find anything wrong and reinstalled the lower unit. Still no water.
I'm looking for any assistance you guys may have from either your own experiences or just your expertise. Thanks!
SB
SB
