Long story short I?m going back together with a 1971 1350 and want to know what is safe to use as gasket sealant on the water jacket cover that fits around the exhaust ports as well as I have read some ware in this form that a two part thread locking epoxy should be used on the bolts when installing this. I would like to know
What to use as gasket sealant on the water jacket cover around the exhaust ports
What to use as thread locker on the bolts for the water jacket cover around the exhaust ports
Am I correct in thinking this should be torque to 150 inch pounds center out
I was thinking of using permatex ?the right stuff? rated for 450degrees continuous as gasket sealant and locktite blue rated at 300 degrees as thread locker what has worked for you? In this area should I be looking for a sealant that has gasoline resistance or would the normal oil resistance type silicone sealant stuff work?
Thanks
Jason
Thanks
Jason
