water leak at pump 150 outboard
newberry
86 150 johnson removed lower unit,because colored oil in lower unit,just purchased,water in oil,connected water to lower unit and water came out around drive shaft top part of pump,also small hole in water pump maybe air bleeder,does either place suspose to have water running out.thought this water may be going down around shift rod . thanks newberry
OBJ
Re: water leak at pump 150 outboard
Hi newberry.....<br /><br />Not sure why you connected a hose to the lower unit with it being off the engine but, the little hole is for drainage and acts somewhat as a pressure relief. Some water coming up around the driveshaft would not be surprising with a hose attached. Hose has a lot more pressure to it than the water pump impeller would. Between the impeller housing and impeller cup is an oring that helps prevent water from discharging up along the drive shaft. Other seal points are, two seals under the impeller plate, two prop shaft seals, shift rod oring and gasket under the shift rod cover, and a large oring on the prop shaft bearing carrier.. If you want to find your leak, rig a bicycle pump to either the drain or vent plug and put about 10 to 15bls pressure in the lower unit and dunk it in a garbage can full of water. Should show up right away. If you don't have a service manual, I strongly suggest you get one. Iboats have the generics. Most folks prefer OEM manual speciffically for their engines. Manual for your engine are still available. Hope we have helped.
newberry
Thanh you outboardjim,when i removed lower unit saw signs of water in that area just curious about where it came from so i checked to find out.also signs of oil around small drain hole near water intake on lower unit made me think leak near water pump.thank you and will check with low pressure 15 pounds newberry
