Hello,
I bought an '84 Bluewater with a 2.5 Mercruiser and Alpha 1 outdrive last year. Used it all last summer and winterized. Must not have done the best job because it is leaking water behind the bellhousing and down into the flywheel. I understand I may be an idiot for not properly winterizing and I accept that.
Today I decided to tackle this issue. I removed the stern drive and pulled the engine. Removed the flywheel and I can't see anything wrong. Both "freeze" (not what they actually are meant for) plugs are still there and I don't see any cracks in the block.
The water was leaking in when I was the running the engine on muffs and when I went to the lake a couple weeks ago. I'm not sure where to go from here.
Thanks
Thanks
