Water leak into bilge... bellows?
hangdogger512
This question is in reference to a leak on a 92 GW Invader with Mercruiser 4.3LX (OD820725) and Alpha 1 Gen II drive unit.
I just bought this boat a couple weeks ago, and am new to owning an I/O... have had outboards and am a seasoned mechanic though. Knew this one was gonna take some service and rebuilding, but am trying not to go overboard with replacing everything! ;-)
Took it out on the water for the second time yesterday (engine and drive did awesome), but noticed that the auto bilge was running quite a bit. So I climbing into the dog house and found a fairly large substantial leak coming from what appears to be the exhaust bellows? Anyway, just hoping that perhaps some of the seasoned folks here could verify that this looks like a bellows leak? If so, I will order a seal kit and take my first go at removing a drive unit! ;-) See video link below to see the leak...
https://youtu.be/Mpjk7VzGYhU?t=25s
Thanks in advance for any advice!
kenk63
you can check for cracks or tears in the bellows for the rear, lower up, then lower down and then left to right, look for cracks, feel for holes where you can see, replace all three, also recommend replacing the **** cable since your there already
Bt Doctur
Looks more like the exaust Y pipe has sprung a corroded hole thru it.exaust bellows are outside the boat and even if they were removed you would not have that type of leak. Can confirm it by running on muffs and seeing if its warm water draining from the boat
hangdogger512
Bt Doctur Yes, actually, I did notice that there was warm water leaking when I ran it with muffs yesterday before taking it out. So, that indicates a a corroded exhaust pipe?
Bt Doctur
Yepper, water leaks from the rear of a motor are mostly exaust pipes or in the worst case core plugs popped behind the flywheel
Bt Doctur
Unless you also dead and gone to Heavan , Don wont be giving you an answer
Nah, there cheaper on the net
hangdogger512
Hahaha, sorry for the little text! And yes, I am sure that this question has been answer a ton. So thank you all for your time. :)
Follow-up, for replacing the exhaust Y, I assume I'll still need to pull the drive... so, as a standard precaution should I just do the bellows and gaskets anyway?
Ayuh,..... Welcome Aboard,.... Ya, ya gotta pull the drive, so you can pull the motor, to replace the Y-pipe,....
If you don't know how old the bellows are,...
Yes,... Change 'em All,.... they're a 5 to 8 year replacement parts,....
hangdogger512
Thanks Bondo. And crap, so this is a motor pulling adventure also?
I was planning on paying a shop to pull it this fall so I could do some deck work, as I don't have an engine hoist at home. So, question, If my bilge pump keeps up with the leak, what are the risks of running it with the exhaust leak for another month or so? Hate to lose the last bit of summer with an engine pulled.
Bt Doctur
You have to ask yourself if the danger of sinking with your family is worth the risk . Whats going to happen if the bilge pump decides to stop pumping or if the small hole breaks away and you have a 2 inch hole.
hangdogger512
Okay, did a little more digging tonight thanks to yo ur info Bt Doctur and Bondo.
Ran it with muffs again and I was wrong, there is no warm water making it to the bilge drain. Only out the exhaust ports. But in turning the drive and inspecting the bellows, I did find that the small bellow on the shift cable is completely torn. Could this drain back into the bilge while the boat is sitting in the water? I could see this size opening causing the volume of drip in the video. Maybe I'm just wishful thinking...
I also did inspect as much of the exhaust as possible and it looked pretty good. Thinking outload here... If it is indeed the exhaust pipe, why would it continue to leak in while the boat isn't running?
Here are some pictures...
Save
Grub54891
Yup, You found the problem. Replace all the bellows, lower shift cable, gimble bearing and trim pucks at the same time.
Ayuh,.... The exhaust is fulla lake water right up to the shutters when not runnin',...
camalot
Though your bellows looking way past there due date, I would look at the seal where the hydraulics go through the transom.
hangdogger512
No Title
Thanks Grub54891 Bondo and camalot
I think that's my first line of attack... replace all the bellows, gaskets, shift cable, gimble bearing and trim sensors. Then take it for a short run on the water... should be able to tell pretty easily if that was the issue.
Now, for my related question: I can tell that with this leak the previous owner let water come on fairly deep (few signs of water up by the trim pump, etc). So, whats the best way to check and make sure that water never made it into the transom plate? I can see some water damage on the port side at the top of the plate where it is exposed (and looks like it was cut away to allow a path for the fuel fill line. But it certainly could have seeped into the center as well, right? How can I ensure that the plate is solid? Everything else looks pretty solid and dry (except some of the decking is soft and needs replacing... which I am planning on doing this winter).
Thoughts? Advice? Drill and seal?
Few pictures, just cause...
wahlejim
Plan on a new starter soon. If water made it to the trim pump, it was underwater and you are on borrowed time.
First, you need to look at the bigger picture and figure out the cause of the soft spots in the deck. A lot of people buy boats thinking tey can just change out sections of soft floors only to dig into it and find major issues with stringers. Before you drop too much money in the boat, you will need to determine how much work has to be done, and if it is worth it to you to do it.
If it were me, I would change out the bellows and only the bellows to finish the season up. They are relatively cheap and easy to do. I don;t like throwing money at projects that I don't think are worth it, but that is ultimately up to you to decide.
