Nextelbuddy
- Joined
- May 4, 2020
- 156
1996 sea ray 210 mercruiser 5.7 alpha 1 gen 2 setup. speedometer has never worked since i owned in past 2 months. i did replace the broken plastic connector that connects the hose to the outdrive when i did my bellows kit installation.
i've replaced all bellows with mercruiser quick silver oem kit with bellow adhesive.
i've resealed the garboard drain plug flange with 4200 (it was loose and could move when tightening the drain plug)
i noticed i still take on water in the bilge even with in an hour and this is with no swimmers getting in and out to leak water into the cabin area.
i poked my head in while floating and engine idling and also while under way with someone else driving and i can not see or hear any water coming in.
the water doesnt appear to come in while just floating, it mainly happens if i drive for a while and ten stop and the bilge is filled enough to eject out with the pump but not enough to trigger the auto bilge.
the only things left I can think of that would leak into the bilge are:
- Lowrance 3500 transducer fitting in the bottom of the hull
- speedometer hose possibly broken inside the boat causing water to get in while under way
seeing how small diameter the hose is for the speedometer i dont think its large enough to let more than a gallon of water into the bilge in an hour while under way but i could be wrong.
was wondering if anyone else has ever experienced a leak from the speedo hose and could weigh in on what their experience was?
things will try this weekend:
i will be double checking the intake inlet hole on the front of the outdrive to make sure its not clogged and i also will have someone look at the speedo gauge while i attempt to blow air into the hose to see if the needle moves even a smidge.
i suppose i would hook up a barbed fitting to the speedo hose hose and then attach a small water line to it and see if water pressure causes air to move the speedo needle or if water makes its way into the bilge area somehow.
i need to research the Lowrance 3500 transducer thru hull diameter and see what else out there will fit into the same hole as my Lowrance 3500 doesnt even work anyways so i am going to replace it with a new system and buy only if i could find one that will fit into the existing hole
