I sprung a leak this year that I can't seem to track down on my Aplha 1 Gen 2. I've replaced the U Joint bellow and shift cable bellow along with the upper swivel shaft pin and seal (all of which was needed). I no longer have water up top or midway up etc.
This leaves me to believe the leak is 1 of 2 things. The Exhaust Y pipe oring OR trim manifold junction block gasket.
Questions:
1) Can you buy just the gasket for the trim manifold junction block? How often do these leak?
2) Whats the best way to test if the Exhaust Y oring is leaking?
Questions:
