arriva2001
- Joined
- Feb 15, 2015
- 64
Hi,
I've been paying a little extra attention to my Force 150 lately, as I'm questioning some of what the former mechanic was doing to take care of it. He removed the thermostat which caused an overheat problem for me. I have another thread about it if you are interested in the outcome.
Anyway.... I noticed that there is a water deposit stain under the cowl. From the water deposit stain area, it looks like it's coming from the top of the Exhaust manifold maybe where the gasket is located. I circled where it seems to be originating from. You can see in the lower left of the picture that the water deposits are kind of all over in there...but that appears where it starts.
I run the engine and I can't really see any liquid water so I don't know for sure where the leak is.
A couple of questions. Is there anything I can do to stop this mysterious leak that I can't find? Can I tighten down the bolts in hope that maybe one's just too loose so the gasket isn't quite seated all the way? or can I put some sort of sealant around the edges of the gasket so it stops leaking? Or do I have to remove the entire manifold and replace the gasket (this option scares me a bit, because those bolts are hard to get to near the bottom, and I'm not even sure how I would be able to get to them especially if they are even a little rusted.
I was thinking about those products that people put in radiators to stop leaks...that cause the gaskets to swell. Is there something similar I could use here?
Or if the thing isn't wet inside after an afternoon of boating...what's the harm in leaving it alone as long as I monitor the situation to make sure electronics aren't getting wet or something. Maybe the leak was really old and the mechanic torqued the bolts before and it fixed it? Not really sure.
Here's the photo so you can see what I'm talking about. There's quite a bit of hard water deposits in there...so this must have been either a very small leak for a very long time...or it was a pretty big leak.
