10thHawk
- Joined
- Sep 13, 2009
- 96
After launching, I had the boat tied up for about ten mins. Was about to close the engine hatch and untie when i saw water in the bilge. Went back home, took the drive off. The bellows checked out. No issues there.Went back to the ramp a week later to try and located the leak. All I was able to see was a trickle of water coming down somewhere directly above the plug. Couldnt get in to see where it was coming from.
Acting on some suggestions, I removed the Mercathode plate on the bottom of the gimal housing(Bravo 1). The two wires coming through did not seem sealed good. Was a white moist goo in the hole, best thing I can equate it to is, well, snot. Tried to remove the plate that goes over the manifold for the hydrolic lines but it would not come off. I snapped a picture of what I'm referring to.
Does it look like this is not sealed up correctly? photo shows up when you click on it.
