water leak
nerrad
i have a 1995 30 hp evinrude that i just changed the h2o pump imp. on i have water leaking from a hole on the back side of the mtr shaft above the lower mtr mount and inside the cowling on the back of the mtr below the lower cylinder :confused: thanks the draketaker
Solittle
Re: water leak
My guess is that you did not get the water tube seated properly when you reinstalled the lower unit. Don't run it that way as you can cook the engine.
nerrad
Re: water leak
is that the tube that is about 3 inches long and about the size of your finger
