Hi all. New to the site........ I recently puchased a 1984 Four Winns w/ a Mercruiser 470 (3.7L). After taking her out a few times, I noticed a large amount (several gallons) of water that drains when I pull the plug. I think I've been able to trace the source of the water. At the rear of the engine, on the starboard side, I can see a steady drip of water exiting the engine while running. It's dripping from under the engine ID tag that is rivited to the block. It appears to be dripping out of a hole in the bell housing. I assume it's entering the bell housing from somewhere above, and exiting thru the only hole. Any thoughts on where this water is coming from? Any info is appreciated. Thank you.
Mark
Mark
