Hi. I just replaced my water pump, exhaust cover gaskets & powerhead base gasket on my 1996 Evinrude 88 spl.Upon starting water seems to be pouring out of the area where the drive shaft engages the powerhead. At this point I'm not sure if the water is leaking from the powrhead / adaptor plate area (I see no evidence of a leak at the gasket area at the outside of the joint) or if possible it is shooting up the drive shaft from the water pump housing. As I have no desire to needlessly remove the powerhead would anyone know if there is a method where I can single out the water pump theory? Can I remove the lower unit, hook a garden hose to the water tube & start the motor? The thought is, if no water is leaking from up top than it must be shooting up the drive shaft? Any thoughts would be much appreciated.
