Water leaking under shaft
babikov
Hi,
During this last season I noticed that some water leaks into the boat. Nothing that could make the boat sink, not even enough to engage the bilge pump. For example, in 3-4 hour fishing trip I would get around half a gallon or so. When the boat was in the water overnight I got close to half bucket. I thought initially that there may be an issue with drain plug, and resealed it carefully. But the problem persisted.
Winterizing the boat I did run it on muffs for 15 minutes and found about half cup of water in the bilge! I looked carefully at all hoses, connections, etc. Everything was dry. However, I found a wet spot on those heavy metal parts attached to the transom, right below the shaft. Most probably the water gets in somewhere just below the shaft. There must be a bearing, correct? How the water from the cooling system (when the boat runs on muffs) gets into the bearing? Does it mean that that corrugated rubber hose (called bellows?) is also full of water? Is it going to freeze in winter and damage the U-joints?
I found no visible water in the outdrive when I drained the gear case liquid. I collected the liquid and let it sit for few weeks – still no sign of water there, although the liquid does not look the same as new (it is not transparent anymore).
My question is: From the symptoms I described, is it possible to narrow down the possibilities of what could be wrong? And what is needed to find this out for sure? [FONT=&quot]Should I entirely remove the outdrive and inspect the bellows from the inside?[/FONT]
The engine is 1993 4.3LX/V6 Alpha One Thunderbolt Ignition, serial number OF0244564. The drive is OD886515.
Thank you for your advice!
Grub54891
Mine was the block that the trim lines go to,on the exterior down low. Gasket went bad and caused the leak. Time to check all your bellows and seals. Water un the bellows is not good for the gimble bearing and u-joints.
Grub54891
After re-reading the post-if its doing it on the muffs,check the intake hose,it attaches to the gimble housing back behind the motor.
Fishermark
...Should I entirely remove the outdrive and inspect the bellows from the inside?...
Yes absolutely. You need to remove the outdrive to check things out on an annual basis anyway. Chances are good you will see water in the bellows. The small amount you saw after running on the muffs could simply be some excess water left over in the bellows splashing back into the boat.
Fishermark
Another possibility is the exhaust Y pipe - either the o ring seal where the pipe connects to the transom housing... or the pipe itself corroding. If it was leaking, the water could get in when on muffs as it exits through the exhaust.
