Water Logged Foam
btomlins
I think the foam under the floor is water logged on my 1995 OMC Roughneck 1768AW. I weighed the boat and trailer the other day and it weighs 2880 lbs. I think that is way to much. Is there anyway to dry it out or do I need to completely remove the aluminum deck and replace the foam? What kind of foam board is recommended?
Grub54891
No way to dry it. Has to be replaced with new foam. Two part pour in foam, 2lb density. Any other foam board is just wrong.
steve_h7
Ditto to 2 lb. foam...
I used some and it worked great.
btomlins
Ok, so I remove the deck and the old foam. Then I pour the new liquid onto the floor and trim to top of floor stringers, correct? Re-attach floor with pop rivets again. Sounds easy but I know better........Thanks!
got pics? we may see something to help you out, however that sounds about right.
Grub54891
I laid the deck first, then drilled 1.5" holes at strategic locations and poured it in starting at the stern working fwd. it gave the foam a place to exit as i went along. trimmed the foam at the holes, and glassed the plugs back in. then laid a layer of glass over the whole deck.
btomlins
Here are a couple pics of my aluminum deck on my Jetboat. You can kinda see the foam in the hole. If you squeeze the foam water squishes out.
btomlins
This is what I found when I pulled up the floor. As I expected. Saturated foam.
you can either use the 2-part foam or you can use poly foam sheats and cut to strips.
jbcurt00
Pink, blue or green XPS sheet foam, depending on where you buy it. Its Extruded Poly Styrene.
Not EPS, its the white foam stuff styro coolers and cups are made of. Its Expanded Poly Styrene. Dont use it.....
In a fiberglass boat, I'd use pour in foam, but thats a whole different conversation....
btomlins
I was thinking about drilling some small holes through each rib in the floor to aid in water drainage and running some wiring through them. Would it hurt the structural integrity of the ribs?
depends where you drill.
the boat lasted 25 years with a bit of neglect prior to you tearing the floor out.
if you put it back the way it was and simply keep it in the garage to keep water from sitting in it, it would last indefinitely
