strokeoluck
- Joined
- Jan 4, 2009
- 353
I took our boat (see below) in to the marine shop for winterizing and a few other misc. things. Stupid me, I didn't cover the boat when I took it in. Don't ask why, it was just stupid not to do it. So there it sat, outside along with 100 other boats. They told me it would be 2-3 days. After 3-4 days I called them and they said they lost the work order but they'd get right to it. Then I had some travel and by the time I got back to town the boat was at their place for two weeks, mostly outside during that time. And since it's normal fall weather here in MN it was raining and/or snowing half of those days.
The boat's now in my garage and it's pretty water-logged as you can imagine. I jacked the front way up, opened all the hatches, took everything out to dry, took the wet/dry vac to the carpets and any other nook and cranny I could find. When I opened the engine cover I noticed that the engine had dew-drop type moisture all over it. (See pic) Is this damaging to the engine? I wiped it off the best I could but there's still moisture on it.
Also, while looking in the engine compartment I noticed that one of the duct-looking things (?; see pics) had a "tear" (?) in it. Are these things designed to pull the fumes out of the engine? If so, is this tear/hole normal? Just want to make sure it's not supposed to be connected to something down near the bottom of the engine.
Thanks!
Thanks!
