Hey guys, I have an old omc stringer drive, electric shift outdrive with a Chevy 350 engine. Usually the cooling system blows water out of two exhausts at the back of the boat. Recently I noticed a leak at the gasket on the port side of the outdrive where the fresh water flush system is mounted. The starboard side where the hose attaches had no leak). The water flow from the port side exhaust seemed a lot lighter then from the starboard side but it was not overheating.
I removed the leaking side and used rtv gasket repair to repair the leak. After I had finished the job I started the engine with the outdrive in a barrel of water (in other words taking in water as it would at sea) The leak seemed to have stopped but now there was NO water coming out of the port side exhaust and it started to overheat the engine.
The question I am asking is where might there be a blockage that would prevent water from flowing through the port side and out that exhaust as it is still flowing through the starboard side as normal, and, might the so called "repair" I thought I made have something to do with it.
Thanks for any help/ suggestions you might have. I have attached a pic of the engine so you can see some of the hoses. The engine has been deemed a "frankenstein" on this forum before so I am aware of it's strange appearance but it has run extremely well for four years like this.
