CharlestonFF
- Joined
- May 3, 2013
- 14
So I decided to check the lower unit oil on the boat I just bought. And out comes clear water with no Oil until the very bottom. The Oil is more like mud and sludge. I don't know how long it has been like this and how much running has been done with the conditions the way they are except for when I test drove it twice for no longer than 30 min at a time. I did notice when I turned it would or what I thought at the time cavitate because the engine was not trimmed down all the way. What are the chances of it slipping and causing the RPM's to rev up and the boat not go anywhere? Is there any test to see if the gearing, bearings, and whole lower unit needs to be replaced? The prop does have a little play when pulling it from bow to stern, but no play port to starboard. I know the vent screws at the top didn't have any gaskets is this normal? The top screw and bottom fill screws both had rubber gaskets! There is a little oil where it had leaked out from around the prop in one spot! Any ideas as to where I should start?
Thanks for the help guys
