Reboot11133
- Joined
- Nov 11, 2007
- 74
I just completed replacing a blown piston on a 1984 85hp force engine. I used Frank's method of going through the reed ports. It worked great! I started the engine this morning with muffs on and noticed water comeing out of the exhaust snout. Is this normal?? I am concerned because when I did rehoned the cylinder I stuffed some rags in the intake and exhaust ports. A couple of rags in the exhaust port fell in and I was not sure what to do so I attempted to remove the exhaust cover on the side of the engine. Bad move! I broke a couple of bolts off. I attempted to use an easy out but it snapped off in one of the holes and I cannot get it out. When trying to drill it out the drillbit wandered off to the side so I tapped it and used a smaller bolt and left the original in. I get a bit of water leaking around this bolt but as long as it isn't getting into the exhaust chamber I think it is ok. I might try using JB weld to plug the leak.
