water outlet for johnson cd 17 5.5 seahorse
jacobreed
how much water should come out of the water outlet and is the cd 17 and the cdl 17 the same motor
Scaaty
Re: water outlet for johnson cd 17 5.5 seahorse
Good spray is fine...CDL is just a longshaft..no diff in the motor. If you don't know that last impeller change, have it done, or get a manual and do it. Think ya have to pull the motor block (6 bolts/nuts..no biggie) to get at the shifter rod to disconnect for the lower to seperate.
jacobreed
where can i get a fuel pump kit for this motor thanks for the help
