water over the back of bass boat
jorja rayne
i have just bought a 16 foot bass boat with a115 suziki engine 16 foot .had it out yesterday .when hitting the gas boat stands up in the front and seems to take whatever power it has to get up and plan off .when it does its fine ontil i let of the gas then it sinks its *** in the water and the wake from the boat comes in over *** off the boat.theres an new prop on it .i dont know what pitch it is.the tages on the boat sayed it is rated for that motor.theres a rear inboard fuel tank that is in the boat.witch only had 10 gallons of gas in it. the boat was built with tank in it.the boat does 45 miles an hour when trimed out.any help would be awsome thanks
sphelps
Re: water over the back of bass boat
Have you checked for wet foam? That may add some unwanted weight .
You could also try trim tabs . Is the motor trimmed all the way down when you take off ?
Ayuh,... Welcome Aboard,.... Slow down, Slower, so's the back-wash don't come over the transom,....
I had a 91 Cajun ProSport 150 (15') last year with a Yamaha 85hp. It was exactly the same. You can learn to slow down gradually so you don't get water over the back. I never experimented with adding weight to the front but I'm sure it would have helped. If your boat is like mine all the weight is in the back. If I had kept the boat I would have moved the trolling batteries to the front.
dan02gt
Backwash is common on bass boats. I fact almost all of them do it. Like Bondo stated slowing down slower will help minimalize it. Also trim down before you drop off plane. I would always wait till the wake was about to hit the motor and blip the throttle a little to outrun the wake.
Like others have said are you trimming all the way down when you go to get on plane? If you are what prop are you running? What's your RPMs on the hole shot?
edthearcher
I had an 18 foot bass boat 145 evenrude, bought used, had a whale tale mounted on the engine, the bow wanted to come up out of the water to high, purchased a pair of smart tabs easy to install wow what a difference it made. as for water coming over the transom i believe this is common on bass boats when you slow down to quick thats why they have that large drainage area in front of the motor
midcarolina
Check and see where the av plate sits in relation to the bottom of the boat......years ago I bought a used small bass boat, the av plate was several inches below the bottom of the boat, the dang thing took forever to plane..... installed a jackplate and set it where the top of the water intake was just below the bottom of boat......thing ran like a different boat!
And for the water over the boat...... do as Bondo said...
