Within the last year have bought some used boats and engines down here in Florida and have concluded that it is normal to find the cooling water passages in the heads clogged really bad. A 1990 Johnson 115hp, a 1991 Johnson 6hp, and now a 1993 Johnson 25hp, all the same, they were overheating in the test tank or flusher, tested with two different infrared guns. I opened them up and it was clear to see why they were overheating, the passages were totally clogged. An engine can pee great with the heads totally clogged, as the pee outlet is before the water gets to the heads.
I've also gotten five (yes five) little Force outboards 5hp within the last 6 month, they were practically unused, yet three were totally clogged. Keeping score? Eight engines, and only two were not totally clogged. That's Florida, where people can go out in saltwater year round.
In all the engines I had to remove the heads (and deal with stuck bolts, broken bolts!)and physically clean them with screwdrivers, SS wool, sandpaper, wire brushes, drill bits, whatever, till all the obstructions are removed. Then install new headgaskets, cover gaskets, diffusers ect. Today I had to do it on the 25hp Johnson that I just bought 2 weeks ago. Not a fun job. Used Florida outboards? Test them in a tub with a infrared thermometer gun before you buy! I will from now on.
