WATER PITCOCK
wltcpatrick@yahoo.com
I LOST MY PITCOCK ON A AQ131D MOTOR AND WAS WONDERING WHERE I COULD FIND ONE OF THESE OR IF ANY ONE NOWS THE THREAD PITCH OF IT SO I CAN REPLACE WITH BOLT OR END SCREW.<br />THANKS
bamadave
Re: WATER PITCOCK
maybe nobody has responded because they don't like to be yelled at while trying to be helpful. Please turn off the caps lock.
dodge1971340
Re: WATER PITCOCK
Hi any lowes or hardware store carries standard thread brass pitcock,and you will not have to pay the high $$ like at the marina. just make sure you get the right thread . I just put brass threaded plugs in all mine. 1992 omc cobra 5.0 ford. Hope i helped God bless! Gary
Re: WATER PITCOCK
Most of the Drain Holes in the Blocks of motors are either 1/8"npt or 1/4"npt,.....<br /><br />There Might be a brass adapter left In your motor if you lost Just a Plug......<br /><br />You might have to remove this to install the Hardware store Pitcock.....
Re: WATER PITCOCK
thanks alot dodge and bondo tom i will try lowes hope i can get one soon the only marine for volvo around here is closed after i am off work so i have to take a day off just to go there so thanks alot for the advice.
