Water pressure, Block temperature
gwg
What is the normal operating temperature range? and water pressure range?, from idle to WOT, for a 2000 Johnson 150 ocean pro?
Chris1956
My '98 Johnny 150HPV6 has almost 30PSI at near WOT, according to my gauge. 25PSI at cruise speed is normal.
gwg
Thanks, Do you know what your normal block temperature or water temperature would be?
Chris1956
Most marine thermostats open at 140*F. I would expect them to run a bit hotter than that at cruise.
bob johnson
at idle... my V4 of the same style.. runs 140ish... at wot...it drops to 100 degrees
water pressure is about 25 psi at WOT
bob
gwg
thanks, Im installing both, probably 0-60psi kit, and a 100-250F kit
