water pressure fitting on port side
artysniper
i have a 2000 90 hp johnson , on the port side cylinder head there is a black plastic 90* degree fitting on left side , witch side of the head is for that fitting . left or right i have no water pressure one has a brass bolt on it .
artysniper
Re: water pressure fitting on port side
i need to find out where i get my water pressure from . i have a hose with a 90 degree black elbow that threads into the head on the port side . on the head there are two same size threaded holes one is hollow and the othe is plugged do i put the elbow fitting in the hollow hole ?
jwellcraft
If it's a plastic elbow fitting you put it in the hollow hole not the solid hole because that is for actual head temp and the elbow fitting is for water pressure.
artysniper
thank you for clarfiying this . mechanic put it wrong hole .
