Great forum with lots of knowledge. I did not find an answer I need after searching threads.
91 Johnson 175
Little background:
My water pressure guage stopped working and needle us Under the 0 peg.
Last summer I had a couple overheat horns with no water pressure. worked fine inbetween, so I took to mechanic in fall. He replaced inpeller. Also convinced me to replace VRO and put new seal under power head, as was leaking fuel/oil.
Put boat in water and started and water preasure was low and water shooting out bottom of power head.
Took it back in and shop says plastic plug fell out of hole where another water pressure guage could be installed.
So put it in water last night and no water pressure on guage, but motor was peeing.
Needle actually under peg on the guage. Called shop and they now say 'bad guage' don't know what happened. Told me to run it a bit to see if it starts working.
Any ideas on cause or how to fix? Or am I best off just to get a new guage.
Thanks!
91 Johnson 175
Little background:
Thanks!
