Re: water pressure guage
Hi, I am looking at installing a Water Pressure gauge on my 1988, 3 cyl, 2 stroke, 90hp Merc.
Am I correct in thinking that I can cut the hose that runs from the engine to the tell tale, install a tee, fit each end of the cut hose on two legs of the tee, and run a hose to the gauge from the remaining leg?
I would assume it doesn't matter where the hose to the gauge reads the pressure as it would be constant all through the system??
Also, do I need a Merc gauge or would a generic suffice? What pressure range should the gauge cover??
Thanks in advance!
Donald.
