Re: Water Pressure
I would certainly make sure you have good flow from the tell tale before replacing a gauge. Like I said, some work ok that way, some don't. If you have an air compressor, set the regulator for about 10PSI and give the gauge a shot. If it reads 10 PSI the gauge is not shot. Don't spend money unless you are sure it needs to be spent.
