I have a 1992 100 hp GT Johnson. The water pump isn't pumping like it should. I dropped the lower unit and checked the water pump. The impeller looks fine. So I thought maybe the pipe from pump to the squirter is clogged some where. I blew air from squirter and I didn't see anything come out. So I put water hose to pipe and the squirter squrited like it should. I also have about 1/8" holes on the starboard side of lower unit. I don't think the holes should be there. And thinking that the holes are taking away from the water pump pressure.
