Hi. I wonder if anyone out there can help me on a couple of issues relating to my 1978 johnson (35EL78R).
I recently attempted (with the help of a manual) to replace the impeller on this engine. I replaced it ok and made sure the blades on impeller were in a clockwise direction. (Im not sure if this was the right direction)
When doing this, the shaft popped outa the gearcase so i slotted it back in the gearcase. Im not sure if i done this correctly either.
Anyway. I fixed everything together and started the engine. I found that the engine only pumped water when in gear. It wouldnt pump water when in neutral. Would any of the above be the cause of this? Please help as i dont believe its anything serious.
Im also looking for a starter motor bracket for this engine as the bracket i have on the engine is broken. Thanx in advance
