Mercproject
- Joined
- Aug 8, 2009
- 43
I have a 1966 Mercury 650, serial number 1869630 (made in Canada)
The water pump part number stamped into the housing is 46-38931.
The parts manual I have states that a motor with serial number through to 18889735 uses a water pump # C-46-35976A1
Anyone know what difference there is between the two bases?
Did someone install the wrong base once upon a time?
Also: is there a change up to the replacement base number for this motor?
Will a base with a part number 46-58618A1 work?
The installed water pump is metal, I am assuming plastic replacements work just fine. Is my assumption correct?
Water was getting into the lower unit, but I attributed that to a rusted drive shaft - I have a new drive shaft and am reassembling the motor, and rebuilding the water pump.
Any help, suggestions or parts for purchase are appreciated.
Thank you,
Andy K
Thank you,
Andy K
