water pump change out 82 70hp evenrude
gerald arzie sr
i am having a problem seperating the lower unit; i have all 5 bolts removed and it just wont budge; fresh water use only; is there a trick to this.i have tried this in forward neutral and reverse. any info would be great. thanks in advance:confused:
Joe Reeves
Re: water pump change out 82 70hp evenrude
There are six (6) bolts, not five (5). Remove the trim tab and remove the bolt you'll see under it.
