Water-pump gaskets on 1974 70hp Evinrude??
c903
I am refurbishing a 1974 Evinrude 3-cyl 70hp “Triumph” that supposedly was rebuilt in the past. <br /><br />I am replacing the thermostat and water-pump just for precautionary measures. When I pulled the water-pump, there was not a gasket between the impeller housing and not a gasket beneath the stainless wear plate that the impeller housing sits on. Manual does not show gaskets either.<br /><br /> However, rebuild kit for this engine has a gasket for the impeller housing and the wear plate. I am hesitant about installing the gaskets in case a “clearance” issue is involved. Two gaskets acting as a spacer could create a problem if engine originally did not require gaskets. <br /><br />Any info will be greatly appreciated!
jfm1
Re: Water-pump gaskets on 1974 70hp Evinrude??
some of those kits were for multiple applactions, my 67 don't have gaskets
