Re: Water Pump Housing Gaskets
Thanks guys. I was in a hurry and forgot to add this to the other post. <br /><br />Yes, its an Alpha I Gen II. It doesn't take sealant, and there is a weep hole that was producing the water. That was normal. <br /><br />The guy at the shop was very negative about the internet probably because he viewed it as competition. I have always gotten great info here. <br /><br />As to the manual, I did purchase one from the guy at the shop. Got back and looked more closely and it was for the wrong drive. Only up to 92. Have to take it back next week.<br /><br />We just got the original problem resolved. We had the "pickup tube" that connects the waterpump assembly to the copper tube that runs to the upper unit disconnected. We had installed it at the wrong angle. So, no water was getting to the main water hose. That corrected and a new thermostat installed we have a purring engine running about 170 at idle on the hose. Next test will be the lake. <br /><br />Don S, I downloaded that PDF file, but only got the cover sheet and one more page. Can you repost it? <br /><br />Thanks.
