water pump impeller johnson 200
blitzman17
need to know how often you have to replace had the boat 2yrs, boat is 8yrs old person who previously owned it didnt use it much stream still flowing steady had no problems touch wood!!!! use it in salt water also is it difficult to change ?I am mechanically inclined should i go by the manual,PS I always flush water every time I return from from ocean and bay please help <br /><br />thank you
alden135
Re: water pump impeller johnson 200
Things I've learned on iboats...<br />1. If you don't know when the impeller was changed it's ready for replacement.<br />2. Yes, buy a factory manual. I did and it's the best money I spent. (also, I have a parts manual on order as my engine is old.)<br />3. Changing the impeller isn't too difficult with the proper manual and some degree of mechanical apptitude.<br />4. This forum offers some of the most knowledgable boat advice available.(short of going through outboard mechanic school yourself).<br /><br />Good luck. I'm sure the experts will be along with real advice, I'm just chiming in.<br />John
Brew2
I think you could do a search on "impeller" and read for a week about the various opinions on impeller replacement.<br /><br />I think the general concensus would be....as noted by alden...if you don't know when it was last replaced, now is a good time.<br /><br />Once replaced, I would say every two seasons would be reasonable. If you are running in harsh conditions a lot (silty water, etc.) maybe more often.<br /><br />Cheers,<br /><br />Brew
