I'm the proud owner of a 27' 1988 Sea Sundancer with twin 205 HP Mercruiser 4.3L engines. Outdrives are Alpha One Gen One Oyster White. Temp gage on dash indicates starboard engine is getting hotter (200 degrees) than port engine (145 degrees) at idle speed, but both operate in the 145 degree range when cruising. My guess is the outdrive water pump impeller needs to be replaced. Boat is in the water on a lift that does raise the outdrive comletely out of the water. I am thinking about replacing the impeller while it is on the lift. My manual indicates I do not need to remove the entire outdrive from the boat, just separate the drive shaft housing from the gear housing. Any advice if this is possible would be appreciated.
