Water pump impeller replacement
42canoe
I have a 1981 (I think)Evenrude 15 hp ourboard which has not been run (except for about an hour last year) for 10 to 15 or more years. I have been told that I should replace the water pump impeller before I use it much more. <br /><br />Question #1: is this necessary?<br /><br />Question #2: Can someone fax or email me an expoded picture of this vintage motor to help me with dis-assembly and re-assembly?<br /><br />Question #3: Any words of wisdom or "tricks" involved with this kind of maintanence? <br /> <br />Thanks. usccdet@comcast.net
roscoe
Re: Water pump impeller replacement
Yes its necessary. the rubber hardens and dries out, It will disintegrate and your motor will overheat, or worse.<br /><br />Get yourself a repair manual (bottom of page), it has exploded views, tips, troubleshooting, step by step procedures.<br /><br />If you are near a large library, they often have shop/repair manuals, you can read and copy the pages you need.
moderator1
Moving to Johnson-Evinrude Questions.
