Ok, you have the common sea water pump in your typical outdrive. Then you have a pump that mounts on your engine and picks up water through a fitting mounted on your boat's hull.<br /><br />I've read that you should replace the water pump ever few years. <br /><br />What are the pros and cons of the two pumps?<br /><br />Seems to me an external pump would a whole lot easier and cheaper for most of us to change.<br /><br />Can a person convert to an external pump from a in-sterndrive pump?<br /><br />H.
