Slow Ride
- Joined
- Sep 17, 2011
- 166
I took "Slow Ride" (31' fountain with twin yammy outbaords) out for a ride yesterday and ended up having the port engine over heat. The buzzer went off and I slowed to an idle to check it out. After letting it "rest" at idle the buzzer stopped. I assumed I picked up some grass or something like that and didn't think to much of it. I took off again and ran for about 20 minutes at 3500 rpms. No problem. When I stepped up to 3800, I got the buzzer again. I notice this time that there was no water coming from the tattle tale! I let it idle for about 3 minutes and the alarm went turned off again. I limped home and got it on the trailer. Today I changed the impeller on both engines and went for a ride. The other engine did great. There is a very strong stream of water from the tattle tail. The engine which ran hot did have a steam of water from the tail but it was not as strong as the other. It ran fine and I ran it at WOT for several short bursts and kept it at 4000-4200 for about 10-15 minutes. I think its ok but because it is different than the other, it has my attention. What do you think? Am I over reacting or should I be alarmed. As a starting point, the stream is much stronger than I have ever seen it on that motor. (I bought it used 2 over a year ago)
specs 1999 Yamaha 200hp saltwater series ox66. New (not rebuilt) powerhead with less than 50 hours. Left hand rotation. Max RPM at WOT 5400 with top speed of 53mph. Salt water use all the time. No other symptoms
