87 or 88 120 V4. Just started my boat up for the first time today, and it seemed like the stream of water was not very strong, more like a drip. I had the ear muffs on so that could be part of the issue, but it concerned me because one side of the motor was quite a bit warmer than the other side(it was actually cold after 5-10mins of running). I pulled a line off of the top of the cylinder(little box on top of each bank?) that looked to be a water line and it was dry going across to the other side of the motor. It also concerned me that it was leaking water above where the gear oil reservoir is located. Could that be why there is so little water coming out the outlet? Just want to get everything in good shape before I throw it in the water.
