water pump: lower unit out now what
pikefisherman
Impaller not that bad but does it come off from the top or do I pull the shaft out of bottom? Or should I put it back and call it good?005.jpg006.jpg
ootransamoo
Re: water pump: lower unit out now what
take it out from the top and since you came this far replace it anyways if you have it.
pikefisherman
Thanks for the reply
what do I do about that pesky brass ring on top?
pikefisherman
Up date I got the brass ring new pump back in. Is their a trick to line the spline back up? having trouble!
pikefisherman
Thanks for the help everyone, got the impeller in and is pumping great !wooo wooo!!!
ootransamoo
i always put triple guard grease on the spline before installing back up
